Chauvet Intimidator 1.2 Topic is solved
Lightman
Post by Lightman »
Could you guys please make a file for the Chauvet Intimidator 1.2 I would really appreciate it. Thank you :)
Re: Chauvet Intimidator 1.2
Help us to help you! If you need help creating a fixture please try and find the location to a downloadable manual before posting or attach the manual to your post! Otherwise you may get little or no help.
Lightman
Post by Lightman »
the manual for the fixture is located here
http://www.chauvetlighting.com/fixtures ... _fix.shtml
Lightman
Post by Lightman »
does that work?
the link? yes
Lightman
Post by Lightman »
were you able to make it? thank you :D
jr_00_22
Post by jr_00_22 »
I also am in need of this fixture any luck with config?
