how to create a Led Bar with ScanLibrary?
German Monkey
Post by German Monkey »
I want to build a fixture with Scanlibrary.
It is a Led Bar. (Lightmaxx Platinum Led Bar Tri)
It want to use it in the 27 channel mode.
So it has 8 RGB Spots.
I tried it, but I can´t create a fixture with 8 RGB panels.
It looks like one panel.
here my file:
http://www29.zippyshare.com/v/99448653/file.html
can you help me?
