Request Fixture File for Chauvet DMX Mega Strobe III Topic is solved
richdahl
For some reason I'm having trouble getting the blinder feature working on this unit. I have created my own 2 channel fixture file but am only getting strobe. According to the manual the dimmer is to be at 000 and then the speed set anywhere between 43 and 211. Any help would be appreciated! Thanks! I'll see if I can get the manual attached.
DMXMEGASTROBEIII_UG.pdf- Manual for Chauvet DMX Mega Strobe III
- (931.63 KiB) Downloaded 76 times
Re: Request Fixture File for Chauvet DMX Mega Strobe III
could you upload your fixture file as well? maybe we can find the problem.
to check it is no the strobe itself which is the problem:
> set DMX to 1 for the strobe
> add two par cans fixture in FS, one for DMX 1 and one for DMX 2
> set both par cans (DMX 1 and 2) to 0
> now, set Par can 1 (DMX 1) between 43 and 211
if the strobe works (as described in the documentation), it should works as a blinder now. if this works, there might be something wrong with your fixture file
kwelch007
- FreeStyler Version: 3.5.6
- I Use FreeStyler for: Band
I just made a fixture file for this unit. I went with the 8 channel configuration because...why not? I am posting my file. Works fine for me. No macros or any pretty interfaces, but this light is super simple, so I didn't see the point. Also, the image isn't accurate, but it's close.
Thanks!
Kendell
Thanks!
Kendell
