Freestyler Crash
Djreddevil
Just started using FS
FreeStyler Version: 3.3.2
Freestyler Crash
Post by Djreddevil »
Hello,
I'm having trouble with freestyler.
When I startup my laptop and open freestyler, the cpu-usage immediately goes to 100% and freestylers doesn't do anything. After I terminated the freestyler-proces in taskmanager and restarted freestyler, it's working cpu-usage around 15%. But after a half hour, the dmx-signal freezes and the cpu-usage goes to 100% again. Now I can't terminate the proces, so this requires a system restart. And then back to the start...
Does anyone know what the problem is?
I'm using the DMX4ALL-usb/dmx-interface.
Kind regards,
Djreddevil
FreeStyler Version: 3.3.7
Re: Freestyler Crash
Post by LJ_krede.dk »
you should check in task manager which process is using all the cpu... also try to choose virtual interface and see what happens.
you could also try to reinstall FS and the DMX4ALL driver again
/LJ_krede.dk
Aalborg, Denmark
Djreddevil
It's the freestyler process that takes every cpu power.
Virtual interface makes no diference :(
