problem with color selector Topic is solved
squeeks
Post by squeeks »
sorry if this has already been asked, but i searched a bit and couldnt find anything...
using the color selector
when going from LED (color gradient) to pocket scanner (8 colors) the color selector window retains the size of the scanner, which is about half the size of the gradient selector, is this a known issue with a resolution?
Android Dev (Moderator)
FreeStyler Version: BETA
Re: problem with color selector
Post by Mattotone »
Do you mean when a fixture has both fixed colours and RGB/CMY.
Then freestyler displays a tab to switch between the two and the window does not resize to show the fixed colours correctly?
And sometimes not even show the fixed colours?
This is the error iv been able to replicate, your description is quite vague.
squeeks
Post by squeeks »
ok, what it is, is, for the moving fixtures i have there are about 8 color choices that can be selected from the color screen, its not RGB or CMY they are color wheels, well, when you bring up this screen it messes up the RGB mixing window, because the color wheel screen is only half as tall as the RGB screen
i hope that helps
squeeks
Post by squeeks »
well, it appears to be fixed in the newest beta
Post by Mattotone »
Ahh seems like iv found a new bug.
