ProLights XP 575 Wash Fixture help Topic is solved
nkwai
Post by nkwai »
I'm trying to create a fixture for the above mentioned wash, but got stuck. Don't know where to put the "Color macro", "Beam", "Pan/Tilt fine" and "Control" channels. If someone can help and tell me this it would be great, or even better if someone can make the fixture.
Below is included the channel list (not the best possible picture because of the limitations of the site).
Thank you for any help.
Second part of the channel list
(71.34 KiB) Downloaded 17 times
First part of the channel list
(53.43 KiB) Downloaded 18 times
nkwai
Re: ProLights XP 575 Wash Fixture help
Post by nkwai »
Thank you for your help
XP 575 Wash.pff
(32.99 KiB) Downloaded 111 times
np i'll look into it but if anyone wants to jump in b4 me then please do cause im off to bed its 5:15am and ive been up all night!
nkwai
Post by nkwai »
take your time, there is no hurry :D
Colour Macros are on the 2nd Colorwheel
Fine Pan is the 16Bit in english lol so that was already setup properly
Beam is the frost channel use the frost slider or use the right hand slide out levels.
Cant upload at moment Fixture Creator wont export fixture!
nkwai
Post by nkwai »
OK, thank you for your help, today I've took one wash home to find the correct colors for macro, when I'll finish the fixture, I'll post it in the user created fixtures forum in case someone else will need it.
No worries!
