Cue Folders have Disappeared Topic is solved
arabianknightone
Post by arabianknightone »
I have a problem. I have been using Freestyler for a while with no problems. But all of a sudden for some reason I started having problems with the cue folders. I have been using cue folders for months but for some reason they have all disappeared. When I would create a folder, it would show up in the cue list window, but when you exit out of that window and then go back to it, the folder I just created would disappear. Now what is strange about this I went to Windows Explorer and the freestyler folder and found all of my cue folders under the Cues directory in Freestyler. Now all of a sudden, ALL of the cue folders in the cue list window have disappeared. When looking in the Cues directory, they are all there, but just not showing up in freestyler. I am not understanding why this is happening. I am using version 3.3.2. I've been using Freestyler for 2 years and never had this issue. This issue is urgent so could someone please reply soon?
Thanks so much,
Ryan
