Problems with cues Topic is solved
Fedo
Problems with cues
Post by Fedo »
Hello,
I've got a problem with cues in context with the movement of four Scanner.
First Problem: Then I had one Cue, the scanner show a shape (!) like a circle or rectangle, and a second cue with a fixed position (e.g. for the brake between a song on a live stage).
If I switch from one to the other in the cuelist, they always snap. Though I have both cues defined as fade.
Second Problem: Then I have created an x/y moving cue the FX generator or it consists seperated steps. The masterspeed fader to control the speed of played cue, generated a break if I will be get slower. It's logical, course the scene time/fade time is faster as now. But it is unattractive by a live show...
So is that a case for Buggyfix, or can you give me an solution ?
Thank's
..Fedo
...and :fs:
