How many steps can I sequence have?
How many steps can I sequence have? I have reached 15 steps, but cant go further. I click add, but nothing happens. Thanks!
- Spirit
- FreeStyler Version: 3.5.9
Re: How many steps can I sequence have?
yes you are right in the beginning you can only have 15steps per. Sequence.
but you can change this if you go to the freestyler directory and search for the file Freestyler.InI and open it with a Notepad.
now search for the rule:
[NumberOfScenes]
Number=15
If change number 15 to a nother number you can have more steps
[NumberOfScenes]
Number=15
- FreeStyler Version: Beta
I think the default numbers has been increased in the latest versions to 45
- Spirit
yes i did also notice something like that, but you confirmed it. the new freestyler got default 45 steps.
