Fixture Creator (Aesthetics Bug)
All previous beta Bugs will be moved to here on release of a NEW Beta
Plasma
Post by Plasma »
In fixture creator, when you tick "Enable CMY" the channel names are "Cyan, Magenta, Green" if you then tick "Enable RGB", they change to Red, Green, Blue .. All ok so far! If you then untick the CMY box, they dispear, but when you re-tick it, they appear as Cyan, Magenta, and Green but the RGB box is still ticked. Does that make sense?
You then have to untick and re-tick the RGB box to get them to say RED, GREEN, BLUE. Its only an aesthetics bug but thought I would mention it incase it has repercussions in the usage of the fixture if CMY/RGB are mixed up.
Plasma :fs:
Return to “Previous Beta Bugs”
