Cant get it to work
JPWDW
I Use FreeStyler for: Theater
Cant get it to work
Post by JPWDW »
Hi! I followed this tutorial http://www.freestylersupport.com/wiki/u ... _easy_view but I cant get the 3D view to work. I am trying to setup 2 Chauvet's Colorstrip and one Mini Legend Wash. I added the fixtures to Freestyler, opened 3D magic and added the fixtures there as well. Clicked Patched and returned to user view. Then tested dimmer with the Wash and nothing happens in the 3D view. Any help!?! Thanks in advance!
Re: Cant get it to work
Hello i have take a look at the Tutorial and have been searching for the word "Virtual Interface" but i can't see it anywhere so the Qeustions from me to you is.
did you set the Interface Setup in Freestyler to "Virtual interface"
JPWDW
Post by JPWDW »
No, I had Entecc Open DMX as my interface. Thanks for the help, it works nicely now!
