Chauvet Colordash Accent
JPWDW
I Use FreeStyler for: Theater
Post by JPWDW »
Hi! I am very new to the software and I have always worked with ShowXpress to create 3D light shows, but I recently acquired the hardware from Entecc that supports Freestyler not ShowXpress and so I needed to change my lighting program. I am looking for the Chauvet Accent LED light fixture but wasn't able to find it. Here's the link to it: http://www.chauvetlighting.com/colordash-accent.html Any help is really appreciated thanks!
Re: Chauvet Colordash Accent
i made tjhe fixture for you look at: http://www.freestylersupport.com/fsforu ... =62&t=3676
can you also tell me if everything works fine
