Dimmer Freestyler Topic is solved
Light Master Funk
Dimmer Freestyler
Post by Light Master Funk »
Hello. :)
At the outset I wanted to apologize for my language errors (I'm not good at English:))
Namely, I have a problem .... dimmer in the two devices on the controller Scanic Club Roatry 12 went perfectly smoothly (it was nice to look at them). I decided to start having fun with freestyler:).I created 6 devices,(LED PAR 64 scanic).I created everything works,ok.When I put out par.Goes out like every 5% (
not fluent).For more example, I add video with work revo roll.When operation was controlled by the program and when the Scanic club roatry 12.It's the converter is too slow given the signal or what?
Has anyone any ideas on this? For facilitate matter I checked it on a second different program LightJockey ver. 2.5 the same problem.
I use this converter : http://www.dab-system.com/konwerter_usb_dmx_ob.html
Thanks in advance Damian.
Maybe this film easier to understand my problem :
http://www.youtube.com/watch?v=rBI1xevw ... ideo_title
matt
Admin
FreeStyler Version: NULL
Twitter: twitter.com/hankosky
Re: Dimmer Freestyler
Post by matt »
Looks like it may be your interface.. Its not refreshing fast enough. Try an Enttec Open.
Matt Hankosky
flickr.com/photos/mattxhank
Light Master Funk
ok thanks
wardomon
Post by wardomon »
Better yet, try an Enttec Pro.
matt
Admin
Post by matt »
If cost is an Issue, go with Open.. But if you can afford it, yes go PRO!
Matt Hankosky
Light Master Funk
ok I found the cause ...
The freestyler not change refresh packets.But in other programs it work? it is possible to fix it somehow?
