Eurolite LED Bar 252 Indoor
schade9669
Post by schade9669 »
Here's my Eurolite LED Bar 252 Indoor fixture!
Eurolite_LED_Bar_252.zip
(2.47 KiB) Downloaded 195 times
Re: Eurolite LED Bar 252 Indoor
Post by Jan_K »
Hej Christian.
Think you should note / mark that it is a 6 ch fixture in the fixture name.
The user manual, if anyone needs it.
Eorulite_LED_BAR_252_10.pdf
(1.24 MiB) Downloaded 139 times
Post by Jan_K »
Hej again.
I just had a bit extra time and looked on the fixture.
The fixture is made as a 6 ch but if the fader is used it will be possible to give ch1 the value 1 to 15 and this makes the fixture 12 chanal wide.
This may give some unwanted effects when the other channel are used.
I have made some changes in youe fixture where some of the macro functionallity for ch 1 is added and the total ch is set to 12.
It is not tested (don't have the fixture) but give it a try.
It may not be better than the one you have made but I think the total channel of 6 is critical. :)
Eurolite_LED_Bar_252_12ch.pff
(49.16 KiB) Downloaded 220 times
Return to “Eurolite”
