KLS-4001
matt
Admin
FreeStyler Version: NULL
Twitter: twitter.com/hankosky
KLS-4001
Post by matt »
This is the Untested Fixture File for the KLS-4001.
This fixture uses RGB Segments.
Manual -> http://www.mfevents.de/downloads/manual ... LS-400.pdf
KLS-400.pff
(22.2 KiB) Downloaded 230 times
Matt Hankosky
flickr.com/photos/mattxhank
matt
Admin
Re: KLS-4001
Post by matt »
Also check out the Macros on this fixture.
Matt Hankosky
Cécibou
Re: KLS-4001
Post by Cécibou »
Hi
Thanks a lot for the fixture. I am now trying to create a scene !
SektOderSelters
Re: KLS-4001
Post by SektOderSelters »
Hi there - hi matt,
thx for your work you put in that fixture :-).
But it is not working completely perfect to me (maybe this is because i'm quite new in this business).
The strobe & dimmer functions are working quite all right - although the 'blackout' and 'fade'-options are not working.
But the main problem is that I'm unable to change the colours. Hopefully this is not due to my lack of understanding ...
regards
Maarten1183
Re: KLS-4001
Post by Maarten1183 »
Hello do yo have a fixture from de Eurolite KLS-400? I Cannot find it.
I Hope so.
Return to “Eurolite”
