Ok, maybe I'm stupid...
I've downloaded a config files for my BCF 2000, exactely this http://www.freestylersupport.com/fsforu ... =16&t=2189, then I've uploaded it to my BCF2000 using MidiOx, gone to FS and all works perfectly. But If I shut down the BCF and switch it on again everything is different in FS (i.e. I have Master Intensity on encoded and at the end it is on a fader).
If I resend the syx file all come back working perfectly... Why?
[Resolved] BCF2000 don't save syx file
- Spirit
- FreeStyler Version: 3.5.9
Re: BCF2000 don't save syx file
i have the same issue but i allready did some research about it.
but at end Bc_edit is the only program that can save a .Sys file on your Bcf2000, But Bc_edit will give somekind of Error If you try to upload the .sys file.
and that because of the version of java you use, it only work on a older version of java.
Yes, I get an error too when I click Save in BCEdit... I've tryed also to look for an older java version to install but nothing...
So, what shoult I do, send syx file each time I use my device?
Ok, I've just solved using the software finded on the topic http://www.freestylersupport.com/fsforu ... =16&t=2218, remember to save your preset on the list 1-32 and not on preset 0, because preset 0 will be lost at BCF reboot.
