Yet another question ...... in a bid to fix my "sound to light" problem (see other thread) I've upgraded to 2.96h, however now I can't get Martin LightJockey working because the "Misc" options under preferences is no longer there and I cannot tick the box to "output to martin lightjockey".
Am I going blind or can someone point me in the direction of where the option is in the new beta? I was going to post to ask if the setting could be remembered as every time I start 2.95f even after choosing SAVE, the setting is forgotton. At the moment though I'd just be glad to have the option back, whether its remembered on restart or not!
Cheers
Plasma
New Beta where did the "misc" option in Preferences go? Topic is solved
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: New Beta where did the "misc" option in Preferences go?
preferences -> extra options.
Plasma
I would have bet you my left arm that I'd looked in there and not found it, but right your are, there it is staring me in the face! I was obviously blind drunk when I looked for it the first time!Mattotone wrote:preferences -> extra options.
Plasma
