Stairville TRI LED
HEINEKEN
Stairville TRI LED
Post by HEINEKEN »
Hello
does anybody have the TRI LED fixture file???
would greatly appreciate :D
matt
Admin
FreeStyler Version: NULL
Twitter: twitter.com/hankosky
Re: Stairville TRI LED
Post by matt »
HEINEKEN,
Can you provide a PDF, Link, or any other info on this fixture?
If you get the PDF or a Link, we can make the fixture file for you!
Matt Hankosky
flickr.com/photos/mattxhank
HEINEKEN
Post by HEINEKEN »
Thank you, no longer needed.
Foot controller works fine.
matt
Admin
Post by matt »
We can still make one for you if you would like..
Matt Hankosky
Risingscale
Post by Risingscale »
Hello
I use two "tri led bunddle" with a stairville led commander 16/2.
I want to try these fixtures with freestyler + enttec usb dmx pro.
I discovered the soft ans this topic yesterday.
Here is the pdf of the "tri led bunddle" :
https://www.thomann.de/pics/prod/238663_manual.pdf
I generally use the dmx mode 6 with the commander.
Many thanks for your precious help.
Phi
PS : Hope my english is not too bad. :oops:
matt
Admin
Post by matt »
Would you be open to using mode 4? Looking at the manual, mode 4 allows individual RGB control of each light. This will allow you to do all of your chases in FreeStyler with DMX400 or Cues.
I would create you 2 Fixture Files, a Simple RGB, and a Lamp Control, Then in FreeStyler, you would add 4 RGB Files, and 1 Control file for each unit (5 Fixtures per unit) this will allow complete control over the light.
Matt Hankosky
Risingscale
Hi Matt
Many thanks for your fast answer.
Feel free to suggest the best way.
I 'm a real newbie in the FS world and have many things to learn.
I would be very pleased to start with your files.
Best regards
Phi
matt
Admin
Post by matt »
Please give this fixture file a shot. You only need to add 1 Fixture file. I used the LED Segment feature in the fixture. (You may need to download the latest public beta for it to work right!)
This is for mode DMX mode 4.
viewtopic.php?f=70&t=3604
Matt Hankosky
matt
Admin
Post by matt »
MAKE SURE You set your mode to 4.
You can control the devices individually via your DMX-controller. Press
“MODE” button until it shows , this means DMX address is 001, you can
set the DMX address by “UP” and “DOWN” buttons. If press “SETUP”
button, it will show d-p1, it means the device is in which DMX mode 1. You
can switch these DMX modes by “UP” and “DOWN” buttons. There are 7
DMX modes.
Matt Hankosky
Risingscale
I'm wainting for my enttec dmx usb pro to test it.
I'll post feedback when tested.
Shot added on the "user created downloads" section.
Thank you very much Matt.
Phi
Haku Shiro
Post by Haku Shiro »
hi. sorry to post in such an old thread.
does there a magic 3d easy view ficture exist for this perticular fixture? or anything similar i could use?
edit: the stage tri led bundle is build in, but only in dmx mode 1
edit2: please excuse my massive dumbness, found out how to set it to mode 4
momjovi
Post by momjovi »
Hi folks,
sorry for warming up this thread also. But here's exactly what I need. Has some one that fixture file for the Stairville TRI LED? I would like to operate it in 15 channel mode to have full flexibility of all 4 spots and the inbuild programs!
I tried out the Fixture Creator, but I am a newbie and totally have no clue which type of fixture to chose and what to fill in. I set up the channels and descriptions but then in FreeStyler, I only see the faders on the right. No other windows are available for it.
Thanks!
Djprafu
FreeStyler Version: 3.6.4
Post by Djprafu »
matt wrote: 03 May 2011, 20:22 We can still make one for you if you would like..
Can you do please?
