Hi all I've got a strange problem, all of a sudden my sequence window has disappeared from the screen.. I can see it selects and all the options still turn on fade/snap/off but the sequence window isn't showing!
I've tried to update to 3.3.9 just in case this solves the problem but no luck! Anyone have a clue how to get it back?
Rich
Sequence window disappeared
bluestarprod
- FreeStyler Version: 3.3.7
- I Use FreeStyler for: Band
MartinSLO
- Just started using FS
- FreeStyler Version: 3.4.0
Re: Sequence window disappeared
Same happened to me. Try Window -> Reset windows positions. I think that was my sollution.
DELighting
- FreeStyler Version: 3.3.2
yep, happened to me too but with the color window. I sometimes use a second monitor with the laptop and some of the windows were placed on that other monitor even though I didn't have it plugged in. Because there is no hard edge to the freestyler software you can place windows off the sides of your laptop screen. If it gets to far out you can't get it back and it looks like it's disappeared. Freaked me out once too.
MartinSLO
As I wrote, that saves the problem. Click that and then on desired option.MartinSLO wrote:Window -> Reset windows positions.
- plan_G
- FreeStyler Version: 3.5
THANK-YOU!!! I'm out far away from home on a gig... and lost my color window! (right now I'm under a bunch of trees trying to get a signal!). I wasted lots of time reinstalling and trying to figure out what on earth happened and this is all it was...
Hope I didn't mess anything else up in the process! Thanks again.
