I'm switching over to a laptop and while I did get some good recommendations on older computers (2.0 processor, 160GB hard drive and 2 GB's of RAM) I had a buddy recommend getting a smaller computer at Sam's Club.
Everything seems to be similar but the h. drive is 250GB on them and it only has 1 GB of DDR RAM. I would only have the lighting software on this laptop so I imagine performance would do me much better than a larger hard drive, right?
I guess there is also the "security blanket" of being able to swap a computer at Sam's Club for a long time afterwards as well (this is my main reasoning for considering a place like that).
Laptop
matt
- Admin
- FreeStyler Version: NULL
Re: Laptop
I use to use a Netbook for freestyler. I had to use an external monitor because the screen was too small to use sometimes. (Have over 30 fixtures). So i got a used 19" touchscreen lcd on ebay and that worked great with it.
1gb will run Freestyler fine. You could always upgrade it to 2gb. (Most netbooks are capable of it!)
Matt Hankosky
flickr.com/photos/mattxhank
