but.. I want to share a problem, with S2L. the way it detects the beat, it sometimes skips some beats or go mental.
Question #1
is there a better method to detect beats maybe..
the Gain VU seems like a volume stabilizer
and the Thr Beat I set on manual, because if I tune that also on auto, it messed up the black out function purpose, because when the beats goes out the auto levers get crazy and trigger a beat then someone sings. or then a snare goes of. and the baseline also messes up the beat trigger.
another example, a kick goes off, and if triggers 4 beat triggers Gain VU on auto and Thr Beat. on manual mode, its around a pinky size below yellow lines
I use it for 3 dmx lasers.
and my question #2 is. can I make a sequence play when the blackout is triggered because of no beats..
take for example trance, then the beats go's out, its normally a chilled sound for a couple of bars, and when the beats builds up and kick off again
