qspot575 Topic is solved
ih8censorship
qspot575
Post by ih8censorship »
Hey, I'm a bit of a freestyler newb. I need to use a chauvet qspot 575 and I am a bit confused with how to enter information into the fixture creator. the applicable manual for the qspot 575 is at http://www.chauvetlighting.com/products ... _ug-59.pdf and I've been looking at pages 13 and 14. I dont understand what to enter on things like turning the lamp on and off (as there is a range of values) I would appreciate any help at all :)
qspot575.pff
This is what I have so far. Any help on adding colors and gobos? (among other things)
(5.63 KiB) Downloaded 35 times
Re: qspot575
Post by Jan_K »
Hej ih8censorship.
I tried to import your fixture but it failed. "Subscript out of range"
I think you are missing to fill-in values in gobo or color wheels.
Re: qspot575
Post by Jan_K »
Hi again.
Here is a fixtur you can test.
I have added gobos and colors but don't know if it is in correct order.
Please correct or optimize it and then upload it again.
Chauvet_Q-Spot_575.pff
(96.35 KiB) Downloaded 42 times
