Little Blue Ball don't move in Pan/Tilt - Beizer Sh. Windows Topic is solved
paoloduladj
Post by paoloduladj »
Hi to all! :fs:
In the image attached you can see the problem. The Shape is On (rectangle), the scanner move correctly, but tha little blue ball don't move! Is in the center of the area (dmx value pan and tilt 127 / 127) instead the value dmx in output window is 190 / 143.
note: I have tried to make this message in the Bug report forum but there has not succeeded, sorry.
Thank you very much for the answer!
Re: Little Blue Ball don't move in Pan/Tilt - Beizer Sh. Win
Post by LJ_krede.dk »
http://www.freestylersupport.com/wiki/f ... _functions
http://www.freestylersupport.com/bugs/view.php?id=142
the output should change change when a shape is activated
paoloduladj wrote:I have tried to make this message in the Bug report forum but there has not succeeded, sorry.
please, use the Freestyler Bug Tracker
Pm me if you have any problems
paoloduladj
OK! It's a choice of design and the programmer Maybe will reconsider it.
Thank you for this answer (I hope come considered!).
I can't use the freestyler bug tracker because my login is fail.
I must register a new account for use the freestyler bug tracker correct? Can I use the the identical user and password?
Thank you very much! I have donate to the developper and i've insert a fixture... i like this freestyler site and his comunity. Thank you (and sorry for my english... ).
paoloduladj wrote: I can't use the freestyler bug tracker because my login is fail.
yes, the bug tracker and forum don't synchronise the users. you have to make new account for the bug tracker.. you can use the same user name
paoloduladj
OK! Now I create a new account.
Thank you very much for the answer, have a nice evening!
