Blizzard RBGA Puck Lights
DownShades
matt
- Admin
- FreeStyler Version: NULL
Re: Blizzard RBGA Puck Lights
You may want to post in the Fixture Request Forum.. Freestyler only supports RGB with the Color Selector. Looking at this light it has Red Green Blue and Amber. It also has a 4 channel and a 7 Channel mode. I would use the 4 Channel mode. Set the RGB Values up in Fixture creator, and create a 4th channel called Amber. You would have to manualy use the Amber channel as FS would not use it in the RGB color picker.
Matt Hankosky
flickr.com/photos/mattxhank
- plan_G
- FreeStyler Version: 3.5
- I Use FreeStyler for: Band
I'm using the PUCk RGBA's on all 7 channels. Please PM me with your email if you want my fixture files. I was not able to figure out how to post them in the fixture file area due to the extensions. If you follow my posts around, I started this whole thing with the puck lights, so that's pretty much what all my questions have been about
-g
-g
matt
- Admin
Export your Fixture file as a PFF. Then you can upload it to the Fixture Files section of the Forum!
Matt Hankosky
