648/5 ledbar
lightandsound
FreeStyler Version: 337
648/5 ledbar
Post by lightandsound »
Can somebody please describe to me step by step how to make this unit work?
ch1 effects
ch 2 red
ch 3 green
ch 4 blue
ch 5 strobe
ch 6 programs
ledtrix does not show anything in the preview window, no effect is shown on the ledbar, but if I push flash in suntrix the units flash.
Re: 648/5 ledbar
strange, works Perfect if i try it. (FS3.3.9 Ledrix V1.8)
-Did you make a Matrix
-did you address every
-did you have the intenstie on (100%)
1. addres your fixtures the normal way (1,7,13,19, 25 and on).
2.open ledtrix and go to Setup.
3.make the desire Matrix size. (depants on how much Fixtures you have, MAX 9x9 or 81 Led fixtures with 6channels'
4.Start at "Startaddress" = 2 (Because your fixture Red start at channel 2)
5.and at Every Y ch. Skip X Ch. (Y = 3 and x = 3, Because Every RGB ,Skip Strobe/Program/Effects Ch)
6.press Auto address and know it should work.
(if your Strobe Channel also contance the Dimmer/Intensitie channel you need to make a Overrride button or something else for it so you can set your intensitie on or off)
also take a look at:
http://www.freestylersupport.com/wiki/s ... tup_window
http://www.freestylersupport.com/wiki/l ... ain_window
lightandsound
Re: 648/5 ledbar
YES !!!!!!
Return to “Suntrix & LedTrix plugin”
