This is from the old forum
Chreit
Hi!
I've just installed Freestyler 2.96 on my Computer and noticed that the Sunlite 3D Viewer isn't working with this new version.
Is it a known bug or is something wrong with my installation files. Is it possible to fix that problem?
cya, lj chreit
did you download the viewer at the same time?
It may be a new version of easyview available.
2.96a and easyview from fresh install, is working fine at my end.
Chreit
yes, i did download the viewer at the same time.
I've tried do install the viewer manually (link: http://forum.aceboard.net/23684-2445-12 ... nually.htm)
didn't work. Some dll-files aren't in that directory. (MEVP_VB.dll ,DasHard2006.dll)
freestyler 2.96 > 3d viewer not working
directsound
Re: freestyler 2.96 > 3d viewer not working
DID you ever get freestyler 3d to work? am having the same problem thanks Mike
