Start sequence or shape for MHs from touchscreen interface Topic is solved
lemon
Post by lemon »
Hi!
I'd like to use Freestyler with my touchscreen. For this I've created a sequence that moves all my moving heads to a fixed point and fades them out, and also some shapes for them.
What I want now to do on my touchscreen is to be able
- to select the fixtures by touching them
- to start the shapes I've created on the selected fixtures
- to start the sequence I've created (which has to be run once and then stopped automatically)
On userinterface 1 I can select the MHs but there's no possibilty to run the sequence (if it is not on a cuelist) or to start the shapes.
On userinterface I cannot find any buttons to create for the fixtures, the sequence or the shapes.
Hope someone could help me.
Re: Start sequence or shape for MHs from touchscreen interfa
this is only possible with touchscreen UI1 with Touchscreen UI2 you need to work with "Groups"
- to start the shapes I've created on the selected fixtures / On userinterface 1 I can select the MHs but there's no possibilty to run the sequence (if it is not on a cuelist) or to start the shapes.
I think you are missing a point here because it's the idea to programm everything on Override buttons / cuelist or Submasters this is the only way to playback you sequence on the Touchscreen.
(i use the Bezier shape generator only for programming and not Playback)
you can use the Cuelist for this and you need to disable Loop on/off (the green arrows)
I thing you are right there isn't.
(i only use the touchreen UI1/2 for playback and not for programming the light)
