how do you create your own shapes Topic is solved
inthemixproductions
Post by inthemixproductions »
how can i create my own custom shapes like a circle one that moves but I want a heart.
Android Dev (Moderator)
FreeStyler Version: BETA
Re: how do you create your own shapes
Post by Mattotone »
to create shapes.
select a fixture and open the pan tilt window.
there you will see a basic shape.
the red squares are nodes, and the blue squares are handles these handles allow you to change the shape of the curves between the nodes.
moves the nodes and handles to produce the shape you require
hit save
And if you want to go really clever try this http://www.freestylersupport.com/wiki/shapes.bez
