Overide Jams !! (Blue Triangle Error) Topic is solved
RobG
Post by RobG »
Hi All,
I wonder if anyone could help me..
Im trying to sequence, in midi, my ligting rig. I Use Reaper ( a very small, basic but powerful DAW ) to run mp3´d backin tracks with guitar rig live... And now i want the lights.. :geek:
So Ive done a few Scanner Patterns , and Par Fades, set them up in the Submasters and done all the Stop Run Go Back THing via midi ... but im not that far yet... :ugeek:
so....
I tested this Midi triggering just with the overides... and just recorded the midi in my DAW along with a mp3... it seems the midi records ok.
I then Route the midi out from the recorded track, back to Freestyler , and on play back these BLUE TRIANGLES appear.. :evil: . and as far as i can see... these are blocking the incoming midi/dmx from the DAW...
Does anyone know why this might be ??
Maple Midi as a soft midi router...
I wait for any comments in eager !!
RG
:fs:
Re: Overide Jams !! (Blue Triangle Error)
Post by LJ_krede.dk »
http://www.freestylersupport.com/wiki/f ... _functions
if you change values for a fixture controlled by a running sequence (from submaster, cue window or override buttons) you will get the warning triangle.
RobG
Post by RobG »
Ok Im not sure You´ve understood there Kjaere Venn !!
Ill explain hopefully better --
1)Im Only Using Midi Triggered Functions on the Overides - NO Cue window - No Subs at this time.
2) If I "play" the midi triggers in real time - FreeStyler Does NOT show these BlueTriangle Errors.
3) If I Get Reaper to play the Midi back to FreeStyler (just Overides) I get these errors straight away.
At the End - I want to be able to Trigger SM - StopRunGoBack via Midi , and then flash my accents to songs with the OverRides - Have I got this "method" correctly , or should I find a different way ?
Thanks for your quick reply..LJ I Hope u can help me further! Takk paa forhand !!
Hilsen Rob :)
RobG
Post by RobG »
Here´s a quick video of what Im doing.. and whats sort of working and wots not :D
http://www.facebook.com/video/video.php ... 8988670858
RobG
Post by RobG »
PROBLEM SOLVED !
It was the midi data that was at fault... I now have Midi Triggers working perfectly for SubMasters and Overides!!
U can see the vids on the facebook FreeStyler Page! - Cheers All :D
