I've been trying to control FS via a TCP/IP connection. I followed all the docs, and when I call the function 201 to 205 I can control the SubMaster intensity without error. When I tried to use the higher values 507 to 527 it doesn't work. The same applies to all the submaster controls 385 and higher.
Is this a bug, or do they work in a different way? The thing I really need to be able to do is let my application control the specific sequences that are running at any one time. I want this to work in a predictable way, toggling isn't any good because my app will never know what state it was in to start with. Ideally I'd like to be able to tell it to go to a specific line in the submaster rather than having to click back 20 times to ensure I'm at the first entry in the list etc.
Any ideas anyone?
Control commands not working via TCP/IP
Trikkitt
- FreeStyler Version: 3.3.2
- I Use FreeStyler for: Eurovision
- Twitter: www.twitter.com/trikkitt
Trikkitt
Re: Control commands not working via TCP/IP
I think I've just found the cause of the problem... the channels listed in the SendMessage document are wrong....
Right now it shows bits such as
Submaster Run 1 385
Submaster Run 20 405
This is obviously wrong as number 20 would be 404. This has resulted in errors in the channels being out, in addition one bit skips 20 channels for no reason. Working with a fixed 20 channels per use, and this works without error. This means the last channel is actually 484 in the list if my calculations are correct.
Hope this helps anyone else getting problems with that section.
Mike
Submaster Run 1 385
Mike
