Sound2Light Topic is solved
pwsamoo
Sound2Light
Hey all, Does anyone know if the sound 2 light BandPassFreqHz can be adjusted higher then 2000 hz, and if there is a wide or narrow adjustment to the frequency setting, only reason I ask is that there are a lot of songs that have upper frequency beats that get missed, and lights just sit there till the bass kicks in or the auto level catches up, Freestyler is great and is all I use now, I just wish it could do a little bit more with the music detection, if I had the brain to develope I would make it have 2 seperate beat detectors, 1 low freq and 1 high freq and you would have the option of using both together or seperate, anyway, goodday all, just an idea....
- Spirit
- FreeStyler Version: 3.5.9
Re: Sound2Light
Did you already take a look at the FreestylerBugTracker FSBT, here you can ask for a feature request to.
also first read other topics about the sound2light, maby this will give a answer for your quation.
http://www.freestylersupport.com/bugs/v ... g_page.php or press "submit a bug report" at the top of the page
