Interface dropping out
lhunter17
For some reason my SOH USBDMX interface keeps dropping out, i don't think it is because the USB cable is coming out. Is there any way to stop my "intelligent" Winner MKIIs and Rovers from going into S2L mode when this happens?? or stopping it dropping out??
garylites
Re: Interface dropping out
i had a similar problem with my enttec open usb interface, i found that the usb voltage on my laptop was dipping to approx 4v volts causing the loss of communication, easy fix was to use an externally powered usb hub, touch wood, its not happened since.
