Submaster Fader Issue [SOLVED]
mobilegreg
Just started using FS
FreeStyler Version: 3.0.1
Post by mobilegreg »
I have discovered that if I move a Submaster fader before I have run a sequence in that submaster, that the fader will effect all lights. After a sequence is run from the submaster, that fader will work correctly. Any ideas???
Re: Submaster Fader Issue
which version of Fs are you running.
mobilegreg
I am running 3.3.2. This did not happen with the previous version, it started after the upgrade to this version.
FreeStyler Version: 3.3.7
Post by LJ_krede.dk »
Try download v3.3.7 Beta and see if the issue still is there
Sent from my HTC Hero using Tapatalk
/LJ_krede.dk
Aalborg, Denmark
mobilegreg
Thanks. That fixed the issue.
