Launch sequence editor from cue window Topic is solved
russellcframe
Post by russellcframe »
It would be nice to be able to launch directly into the sequence editor from the cue window as that's the primary interface I'm using.
For example:
I'm launching sequences through the cue window.
I'm into a sequence I like and decide I want to adjust something or use it as a base to create another new sequence.
I could just right-click on the sequence from the cue window, click edit and I'm into the editor and could save it as is or as a new sequence as usual.
Re: Launch sequence editor from cue window
good idea... :idea:
Android Dev (Moderator)
FreeStyler Version: BETA
Post by Mattotone »
All ready there mate,
Right click on the sequence click edit, up comes the sequence editor in offline mode so not to affect your running shows.
and done.
Return to “Ideas and Remarks”
