If I have "Loop All Sequences" selected in my Cue window and have more than one multi-step sequence in my cuelist, I expected that the Manual Trigger button would allow me to manually single step through each sequence in the cuelist.
However, it seems that it only manually single steps through whatever sequence is currently active, and then reverts to automatically stepping through any sequences that follow in the cuelist.
Is this the correct behavior?
Manual Trigger & Loop All
- ronblechman
- FreeStyler Version: 3.3.7
- Spirit
- FreeStyler Version: 3.5.9
Re: Manual Trigger & Loop All
i Don't know if it's a normal behavior, never used "loop all sequence"
But if you know it's not normal becaus other versions workt fine.
Submit you bug report Here http://www.freestylersupport.com/bugs
