Chauvet Oceana (Did I do this right?) Topic is solved
GoodnightHero
Post by GoodnightHero »
Here's my first crack at a really simple 2 channel fixture.
Not sure if this is correct.
It works...Most the way. I can't seem to get the strobe values correct (anything below 66 on Channel 2 and it just blacks out instead of strobing even slower, anything above 250 and it stays on).
Oceana.pff
(5.93 KiB) Downloaded 45 times
Re: Chauvet Oceana (Did I do this right?)
Post by LJ_krede.dk »
cpuld you upload the manual for your fixture... Then I (or other users) will the the fixture file for you
Yes and No. the way you maked the fixture this way you can make all the fixtures but if you use the "Custom" fixture in the Fixture creator you can also add the value for the Strobe effect and you can make macro's for the rotation.
but at the end the fixture need to be like you want it, you need to use it.
So u say 0->66 = Blackout, 67->249=Strobing, 250->255= Lamp on
But can you be a litlle more specific about the Strobing.
http://www.chauvetlighting.com/products ... _ug-94.pdf
GoodnightHero
I'm at work at the moment, when I'm back home, I'll gladly post all the information I have.
I'll try remaking it as a custom fixture, so I can set Macros for the different speeds, etc.
