Greetings!
Can you help me? I have downloaded Freestyler, Freestyler TCP/IP Server and the TCP/IP app for my iPhone. I have established a connection between the iPhone and the Freestyler TCP/IP server but when I try to send a command to Freestyler (Toggle Blackout - FSOC002255) I get the following error message...
FSOC002255 Not a valid command! As the code I entered (FSOC002255) is one of the examples, I am at a loss as how to proceed.
If possible, could you sen me some examples of MACROs that I can try to see if they work.
Thanks in advance
Tony
tsenneville@earthlink.net
TCP/IP to Freestyler
- FreeStyler Version: 3.3.2
Re: TCP/IP to Freestyler
Sorry to be so dense but could youshow me how to build a macro from the list of available commands?
I have a couple of questions about using TCP/IP remote with Freestyler:
1. I have figured out the communications protocol and have made contact with Freestyler from my iPhone but I am having a problem:
If I send a valid command (panLeft) to Freestyler as a Macro, all is OK and the Pan channel in the moving light changes value but when I
send the same command from the Terminal, the command is sent and captured by the Freestyler TCP/IP Server but nothing happens until
I send a Marco...any Macro, then the command is executed. Can you shed any light on this problem?
2. Is there a way to add more commands to Freestyler TCP/IP Server? I would like to be able to access all of the functions of a moving fixture.
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
1.
Use your devices Settings to toggle on CR, Line Feed or CR w/Line Feed can't rember which one thou!
2. No. Which commands do you require?
Greetings!
I have set the iPhone to generate a CR + linefeed as a Terminal Suffix and terminal command (ch 6 @ 100) still needs a macro sent after it to get any action. Any thoughts?
