Midi causing crashes Topic is solved
bluestarprod
Post by bluestarprod »
Hi all, I've posted this in the external control as well but I've had no responses and this is now causing me big problems... :(
I've purchased an FCB1010 to control Freestyler from. I have plugged it in with a midi to USB adapter and have adapted both Freestyler (to look out for velocity of 100) (FCB to send out Midi notes). I started up FS and assigned an override button to one of the presets on the FCB and checked it... It worked! Then I assigned another override button to the second preset on the FCB, then when pressed FS froze on me and I could no longer do anything without restarting! I can not get passed this now and now FS seems to freeze on startup until I unplug the FCB! (which is obviously causing me problems as FS won't recognise the Midi control after startup!) I am starting to lose all patience as I can't figure what is causing these problems, has anyone else encountered them? What can I do to get all this midi control sorted.. Would be very appreciative if anyone has done this kind of control and can help me out a little.
Thanks :fs:
Rich
bluestarprod
Re: Midi causing crashes
FCB forum (Mel) solved this one - so I'll post here for anyone encountering the same problem.
Midi Merge - turn off... It was causing all the problems... Turned this off in Global Settings and now have 5 scenes programmed in with no crashing.
Rich
