Chauvet 4 Bar & 4 Play Topic is solved
kingmania
hi, sorry my bad english, please you have found the fixture. ssl for "4 Bar" and especially for "4 Play " Chauvet? I can not find them. Does anyone know how to do? Can you help me? please send them to <removed> please upload to board thanks
djharryg
- Commited FS Forum helper
- FreeStyler Version: 3635
Re: Chauvet 4 Bar & 4 Play
I could use them too!!!
Freestyler: V3.6.35
Freestyler: V3.6.35
GaryBonaducci
Harry, I put up a TEST version of the 4Play fixture in this thread:
http://www.freestylersupport.com/fsforu ... f=8&t=3400
Give it a try and tell me if it works well for you or not. I believe you will need to be using the latest FreeStyler version 3.3.7 because it uses new features. Also, please check the ring patterns on the "Gobos" window and compare them to what you actually see on your fixture. The colored rings should be the same. If not, please let me know so I can fix it.
kingmania
hi dear ...sorry my bad english
thanks for your job ... but i need too 4 play fixture .ssl for 3D. Do you have it?
and do you have too 4 bar fixture .ssl?
can you send me them in mail carmine@kingmania.com
because i cannot check often this forum.
Thanks for you time
Carmine
Thanks for you time
Carmine
GaryBonaducci
Carmine, unfortunately I don't think EasyView is able to display a multiple-lamp device like this. It's limited to only one lamp and cannot display four.
I will be working on a FreeStyler fixture profile for the 4BAR/4BAR TRI soon to demonstrate the new "Show In" and "Formula" features. I'm not sure when I will have time to do this, so keep checking back on the board....
Tascam
Did you ever find the time to create the 4 Bar Fixture file for the visualizer? Thanks in advance for your help!
