I Have 6 Clay Paky Mirror scanners model: Golden Scan ver.1. Well the are to old to control with DMX512. Because they use the former protocol from Pulsar wich uses RS232/PMX-standard. How can i best solve this without create a new program? My old PC from 1990 is dead. The custom program in it was specially developed and backuped, but many years ago on 5,25" Floppy.
DMX512 to PMX/RS232 conversion / bridge
tahlin
Hi!
tahlin
Re: DMX512 to PMX/RS232 conversion / bridge
I talked to theservicemanager at Pulsar and they have a solution. Masterpiece 96 with PMX & DMX512 output. But it will be to expensive for me. They created this desk for old scanners ...
I have had a Grey box wich records the signal from DMX512 ther you can record a show with triggering points but is a different protocol.
