Hallo
Englisch by Google ->
I use freestyle for some time and binn very happy with it, but I have recently unasked to MIDI. My Midi Keyboard works in freestyle, unfortunately, only half the keys are velocity sensitive and only go up to the value 126th Apparently, but min. and 127 required to trigger a scene. Is there any way to put this 127 on down? so that the velocity of the keyboard does not matter or do I buy one again?
About an answer I would be very happy.
Deutsch:
Ich benutze Freestyler seit einiger Zeit und binn sehr zufrieden damit, jedoch habe ich kürzlich auf MIDI ungestellt. Mein Midi Keyboard funktioniert an Freestyler leider nur halb. die Tasten sind Anschlagdynamisch und gehen nur bis zum Wert 126. Anscheinend ist aber min. der Wert 127 erforderlich um eine Scene auszulösen. gibt es irgend eine Möglichkeit diese 127 weiter runter zu setzen? also dass die Anschlagdynamik des Keyboards egal ist oder muss ich mir nochmal eins kaufen?
Über eine Antwort würde ich mich sehr freuen.
MFG
Stefan E.
MIDI Keyboard
S-E-
- FreeStyler Version: 3.3.2
Mavi
- LJ
- FreeStyler Version: 3.2.8
Re: MIDI Keyboard
Vary poor google translation - needed to read the german to understand what he wanted to say (actually I am german to
He is using FS for some time now and likes it. Now he switched on using MIDI. He owns a midi keyboard but it has touch response and so he has problems controlling FS since FS needs MIDI values over 127 but his keyboard highest send value is 126. Now he wants to know if you can set up FS to accept values below 127 or if he needs to buy a new keyboard.
Solution:
First of all try to swicht the touch response off. If this is not working, you can try to use a programm like MIDI OX to modify the MIDI input. I am not a MIDI expert but as I know you should be able to set it up that no matter wich value greater zero it receives it will send out 127 to FS. Perhaps someone knowing this better would like to explain how everything works. I will translate to german for Stefan then
I do not thing you will have to buy a new keyboard.
German:
Zuerst habe ich nochmal erklärt, was du sagen wolltest. Die google Übersetzung ist nicht so gut... Ich musste erst das Deutsche lesen um zu verstehen was du wolltest
Lösung:
Als erstest solltest du gucken, ob du die Anschlagsdynamik ausschalten kannst. Wenn das nicht geht, kannst du spezielle Programme wie MIDI OX nutzen. Diese modifizieren den MIDI Input. Du kannst dort einstellen, dass jedes mal wenn das programm einen MIDI Wert größer Null empfängt, eine 127 an FreeStyler gesendet wird. Ich kenne mich hier leider nicht so gut aus da ich kein Experte auf dem Gebiet bin. Aber falls jemand anders, der sich besser auskennt, das genauer erklärt, werde ich dir das ins deutsche übersetzen.
Ich glaube nicht, dass du ein neues Keyboard benötigst.
Solution:
German:
Lösung:
- wardomon
- Commited FS Forum helper
- FreeStyler Version: 3.4.6
Re: MIDI Keyboard
If my memory serves me correctly...
You can edit the freestyler.ini file for custom velocities.
Quit Freestyler.
Backup freestyler.ini
Open freestyler.ini in a text editor
Look near the end for this:
[Midi]
Triggervalue=40
Edit the number to a value lower the the default.
Save the file and restart Freestyler.
See if it worked.
The trigger value is the midi velocity. Mine is set at 40, I think. Haven't used MIDI in a while.
Quit Freestyler.
[Midi]
Triggervalue=40
See if it worked.
A little knowledge is a dangerous thing.
Mavi
- LJ
Re: MIDI Keyboard
German Translation:wardomon wrote:If my memory serves me correctly...
Quit Freestyler.
[Midi]
Triggervalue=40
See if it worked.
Wenn ich mich richtig erinnere, kannst du die freestyler.ini editieren.
Beende FreeStyler
mache ein Backup der freestyler.ini
öffne die freestyler.ini mit einem Text Editor
suche nahe dem Ende nach folgendem Eintrag
[Midi]
Triggervalue=40
Ändere den Standardwert zu irgendwas kleinerem.
Sichere die Datei und starte FreeStyler neu.
Guck ob es geklappt hat.
Der trigger value ist der MIDI Schwellwert. Ich habe meinen auf 40 (glaube ich), habe aber MIDI schon länger nicht genutzt.
- wardomon
Re: MIDI Keyboard
Mavi; Thanks for the translation to German. I studied it grade school through middle school, but that was in the 1960's.
Let's see what Google Translate does, shall we?
Mal sehen, was Google Translate hat, sollen wir?
Mavi; Danke für die Übersetzung ins Deutsche. Ich studierte es der Grundschule durch Mittelschule, aber das war in den 1960er Jahren.
