im a bit stuck creating a fixture for my laser! i have created simple fixtures in the past but never one for a laser! the laser i have is a CR-TEC SP-RGB. the first problem i'm having is with the pan and tilt once the dmx value gets higher than 127 on both they start to move the other way
the manual for the light is here if you would like to take a look:
http://www.sharepdfbooks.com/G69JPC91JC ... 2.pdf.html
and my very unfinished fixture:
http://www.mediafire.com/?t0obzwekb7e5jjd
thanks
gareth
