Hi Guys,
Great software. I was just wondering if you could create a fixture file for the ACME iSolution iMove 8. I am using the isolution SC250 fixture file at the moment - which is very similar (same gobos etc) but it doesnt have the focus. Many thanks if possible!
Cheers
Adrian
Goldbass Records
http://www.goldbass.com.au
goldbassrecords
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: ACME iSolution iMove 8
Help us to help you! If you need help creating a fixture please try and find the location to a downloadable manual before posting or attach the manual to your post! Otherwise you may get little or no help.
As for adding the focus this is simple for you to add.
Open the SC250Pro in the fixture creator.
Change the Fixture Name to iMove 8
Change total channels to the correct value from the manual.
Insert the channel number of the focus function into the focus channel field.
File -> save as.
file -> export (then upload file to this site)
File -> save as.
goldbassrecords
Thanks for that. I uploaded a fixture file with gif image.
Keep up the good work!
