Open cue, Save Cue and Insert sequence dialog Topic is solved
wardomon
Anybody know if it's possible to have the Open cue, Save Cue and Insert sequence dialog window open somewhere other than the default? It would be nice not to have to keep dragging it back to where I'd like it. I looked in the "Freestyler.ini" file but there's no window position data. I tried "Save as Startup values", nope. It doesn't have a "lock" button, so that's right out. I hate to leave it open when I'm not using it. Any ideas?
Re: Open cue, Save Cue and Insert sequence dialog
I don't know if there is any file containing these values. however i think you should make a feature request. It sounds like a good thing to have. it is a small thing but can be a pain in the a** always to move windows to a desirable screen position
wardomon
Feature request in. Busy morning. Found two minor bugs as well.
great!! no not great,,, but good you found them so they can be fixed
