Elation Platinum Spot 5R Topic is solved
DoeorDie
Post by DoeorDie »
Hello Everyone, I completed the fixture profile creator for the 5R and some how my values got crossed somewhere, but can't figure out where. Can someone please help me out.
Here is what I created and the DMX value manual.
Thank you in advance!!
ps. We're trying to use these for NYE.
platinum-spot-5r-dmx-chartl.pdf
DMX Chart
(61.97 KiB) Downloaded 93 times
Platinum Spot 5R.pff
Profile
(72 KiB) Downloaded 87 times
Reason: Zip file replaced with pff. See why in my post below
Re: Elation Platinum Spot 5R
Post by LJ_krede.dk »
Please remove the zip file and upload the pff file of your fixture instead. It contains all the images the fixture uses and it is easier for other users to download the files to their locale fixture directory.
To make the pff file open the fixture in fixture creator, click file --> export
[EDIT] I have done it for you ;)
DoeorDie
Post by DoeorDie »
Thanks for the help!! Did you get a chance to look at it? I'm not sure where I went wrong...
FreeStyler Version: N/A
Post by remco_k »
DoeorDie wrote:Thanks for the help!! Did you get a chance to look at it? I'm not sure where I went wrong...
If you tell us what doesn't work correctly, we can do that.
Isn't a problem description. Now we must search for the problem (needle, haystack) ourself while you can indicate what is going wrong. So please write an exact problem description of what has happened and what youv'e already tried.
Is the fixture running in Mode "ex" ?
supradude88
Post by supradude88 »
Anything new with this fixture in creator? I need this fixture as well. Thanks
