Issues with Enttec Open?
matt
Admin
FreeStyler Version: NULL
Twitter: twitter.com/hankosky
Post by matt »
Per DJ Support,
Is anyone having issues with there Enttec Open DMX adapter? It not working after 45 Minutes...
End Per Dj Support.
Per Matt,
I have not had this issue
end per matt,
Matt Hankosky
flickr.com/photos/mattxhank
cantyco
Re: Issues with Enttec Open?
Post by cantyco »
nope not had this issue. had it running for 6 hours the other weekend or more and didnt have a problem, incase its per operating system i'm on vista
matt
Admin
Post by matt »
Adam,
You may want to try Updateing your driver with this one -> http://enttec.com/dmx_usb/d2xx_setup.exe
Matt Hankosky
Android Dev (Moderator)
FreeStyler Version: BETA
Post by Mattotone »
am i missing something here...I haven't a clue whats going on, whos Adam? Whys Matt answering his own question??
Oh the humanity lol.
Whats the problem? Enttec open no longer responds after 45mins?
Is it allways 45mins a random time? on the hour etc?
The enntec suffers from noise usually caused by smoke machines, does your smoke machine have a 45 minute timer?
Dmx lines properly terminated?
Dmx lines away from power source?
Usb cable good quality well shielded and away from power lines?
Quality DMX cables used not microphone cables?
Are cables in good condition? No floating earths?
Iv run for hours with no problems after i sorted the problems mentioned above.
Mattotone wrote:am i missing something here...I haven't a clue whats going on, whos Adam? Whys Matt answering his own question??
Me! as in per DJ Support i asked him to put in a post, while i was using it that night,
No that was just a rough guess...
I very much doubt it was that due to it not having a problem any other time!
only one device on line and i think it might be self terminating although ive never had a problem with not terminating stuff
Yes and Yes and Yes
yes and yes and yes
never done me any harm considering i used it on about a 700 capacity room with plenty of lights
Id rather not answer that bit as theres one shitr bit in my line and thats not the cable! :D
matt wrote:Adam,
got the latest... im just going to get pro i think even tho my use doesnt justify it!
Return to “DMX Interfaces”
