Chauvet Vue 4.1 Topic is solved
houdini823
Chauvet Vue 4.1
Post by houdini823 »
Does Anyone have the Chauvet Vue 4.1 fixture file? Or if you can guide me on how to create one I will.
Re: Re: Chauvet Vue 4.1
Post by LJ_krede.dk »
houdini823 wrote:Does Anyone have the Chauvet Vue 4.1 fixture file? Or if you can guide me on how to create one I will.
Check the wiki page. There are some great tutorials how to make a fixture file.
Sent from my HTC Hero using Tapatalk
houdini823
Re: Chauvet Vue 4.1
How do you generate the .gifs? Is there an easier way than going through the light and taking a picture of the different combinations ? Also I assume you will have to treat this as a moving head with a gobo even though it doesn't have one.
Mavi
Re: Chauvet Vue 4.1
Post by Mavi »
What gifs are you talking about? The one for gobos/colors? Justtry to use existing ones matching yours. You can also use a programm like paint to create new ones. You do not have to draw every line exactly like in the gobo. Just create an image which nearly matches the original.
Creating new colors is easy. Just paint the colors you need and save the images.
If you want to crate gifs with transparent background (for example the fixture picture) use a freeware tool like irfanview to save as gif and set the transparent color.
You can of course use other professional tools like photoshop... but with the basic tools I mentioned you will get the job done as well.
I think using gobos is a good way to select the different patterns. You can use macros as well, but I would use gobos I think. There is no "right" or "wrong" on how to create fixture files. As long as you get everything wokring the way you want, you have done it right ;)
dan4governor
Re: Chauvet Vue 4.1
Post by dan4governor »
I know this is an old thread, but did anyone ever make a profile for this fixture? If you have please upload the fixture file, I just bought 4 of these lights and I could really use it.
Thanks,
Dan
dan4governor
Re: Chauvet Vue 4.1
Well I guess no one has made a fixture file for this yet. Here is my best stab at one. Just very basic, and it has a picture of the Vue 2, but it works...
feel free to add to it and make improvements.
dan
dan4governor
Re: Chauvet Vue 4.1
okay so it won't let me upload it because it's a .fxt file...I don't know how to change it, so I guess message me with your email and I'll send you this file.
Re: Chauvet Vue 4.1
open Fixture creator.
Go to File -> Press Export -> Save it and your done.
it should be a PFF File and its some kind like a .ZIP file. it contance everything needed like pictures.
dan4governor
Re: Chauvet Vue 4.1
Thanks Spirit!
okay here is the file:
Vue 4.1.pff
(2.81 KiB) Downloaded 139 times
edgephilip
Re: Chauvet Vue 4.1
Post by edgephilip »
thank you spirit for posting. this works great with my wireless DMX as well!!! :fs:
