problem with Chauvet 200B's
DJNuance
FreeStyler Version: 2.95f
Post by DJNuance »
I am running 8 Chauvet 200b's with freestyler. I am not sure if this is a freestyler issue or an issue with the lights.
using any cue or DMX400 changes in colors always fade even if the cue is set to snap. I am using a Enttec DMX USB Pro it seems like a strange behavior.
anyone else experience issues similar to this?
FreeStyler Version: 3.3.7
Re: problem with Chauvet 200B's
Post by LJ_krede.dk »
open the output winow in freestyler and see how the DMX values for the colour channels is behaving when running a sequence. this should tell you if it is Freestyler which sends out fading or snapping DMX.
also check the manual of your fixtures and see if it a setting which is activated so it only fade the colours.
also, it could be a DMX channel which controls this on you fixture.. check the manual again and see if you accidentally send out a DMX value which could cause this behaviour
/LJ_krede.dk
Aalborg, Denmark
