Eurlotie Moon Laser MS2 Topic is solved
jackbayer
Post by jackbayer »
Hello everybody,
could someone please helb me out with this 8Channel effect?
I can´t get nowhere with any type of fixture I try to create and use.
Here´s a manual:
http://images6.thomann.de/pics/prod/257 ... eitung.pdf
On page 18 ist the dmx channel description. I just don´t know what to insert where.
Thank you very much!
Pmarten8
Re: Eurlotie Moon Laser MS2
Post by Pmarten8 »
Hi Jack
Im working on this for you now will hopefully have it finished for you 2morrow if you can test it once it finished
and leave some feedback
Pmarten8
Post by Pmarten8 »
Hi Jack
Try this Beta v1.0.0
LED Laser MS-2 .pff
(80.34 KiB) Downloaded 60 times
CH3 Librate
CH4 Flash
CH8 LED Strobe
Have to be controlled from sliders on top right hand side of freestyler
There is also a Load More new Gobos, Macro and Colour Pictures included in this fixture
Please Report Any Problems With This Fixture Here
jackbayer
Post by jackbayer »
Hello Pmarten8!
Thank you very much! That´s superfast! :)
I will be able to test it this afternoon and will give feedback!
Tanks!
jackbayer
Post by jackbayer »
Hi I´m testing right now. It works perfectly with but one little exception. The DMX Mode starts at 226. If I press the DMX Mode Button it moves to 225 which turns it off. 226 then again gives control over everything.
Many thanks. I´ll let you know how it performs tonight in real life conditions!
Pmarten8
Post by Pmarten8 »
Hi jack
I had another look at the manual at the channel values and there is a printing mistake in the manual
If you look at dmx values for the CH1 Mode
There are two channels with value 225 printed next to them. Were i was following the manual i did not notice it
but thanks for reporting that
I have now fixed this issues with fixture in this latest release v1.0.1
LED Laser MS-2 v1.0.1.pff
(80.35 KiB) Downloaded 86 times
Thanks Again
jackbayer
Post by jackbayer »
Hi again,
very cool. It works perfectly, even the old version (with the ecxception of the printing error of course).
Total control. I think you can call v1.0.2 a final. Thanks again!
