That was interesting. I was opening and saving different locations while programming some tunes. I had probably opened and closed 3 different locations more than 4 times each, checking to see that all the tunes were where they should be. I noticed that one of the locations suddenly had the wrong tabs...and it had some from other locations. There were at least 7. I tried to delete a tab and Freestyler crashed. I had to reboot. When I restarted it, the starting location was the last one I had open. It still had more than the allowable number of tabs. I tried to delete a tab and crashed it again.
A reboot and restart later got me back into the same situation. I loaded a different location, then saved it immediately under the name of the broken one. Closed and restarted Freestyler. I could manipulate the tabs again.
Whew. All I lost was the tabs for 5 tunes. Quick rebuild from the cuelists.
I don't think I could duplicate the problem and don't think I want to try. I was nauseous. I thought I broke the software.
More than six cuelist tabs Topic is solved
